yes, i mean i want use 4 monitor with one system.
i'm using 7800GT, if SLI can support 3 or 4 monitor with sperate work area, i will plan to use nf4 SLI
版主: Cyber Oxygen
stantang 寫:You will need two of those cards and turn off SLI multi-GPU mode in order to use 4 monitors... If multi-GPU mode on, all cards will work as one, so only one monitor is supported.
acog 寫:stantang 寫:You will need two of those cards and turn off SLI multi-GPU mode in order to use 4 monitors... If multi-GPU mode on, all cards will work as one, so only one monitor is supported.
thats mean it is not running on SLI mode, just plug with 2 display card only... if do, can i use different model? e.g. 7800 GT and 7800GTX/ 7900 ?
