由 sobig » 15日 11月 2016年, 10:13
On the timeline, you can can select key frames that you want.
1. Press "Shift" on the keyboard >>> Left click on your mouse and drag it.
2. Once, you see some key frames are duplicated. Duplicated key frames will be white.
3. Release and drag the key frames to specific timing
4. You can do the same steps in Curve Editor as well.
5. In curve editor, you can select the key on the animation curve and duplicate it with the same way from the above.
Hope this help. good luck.
- 附加檔案
- Timeline.jpg (53.21 KiB) 被瀏覽 5583 次
